Old 25th October 2018, 08:51 PM
Reading through that list, there seems to be two quite distinct instances of something significant happening to throw so many error codes. There is the one on 2004.03.25 which also managed to get quite a few Component Protection errors, and then there is the second one on 2007.10.22. I suspect battery issues of some sort.
As others would suggest, I'd save the log (assumed you have), and then clear all the codes. There is the option to clear ALL codes, but probably wiser to go into each block and clear them (will take longer, but better). Then have the owner drive around for a few days and then get another scan done, and see what's left.
