Old 7th April 2019, 11:31 AM
Originally Posted by DailyMike View Post
Thanks, MikkiJayne!
I'll see if A8parts have one in stock first thing Monday! I need to order 04-off Lambda sensors from them too...I always get error codes relating to them. I mainly run the car on LPG..will the Lambda sensors being faulty effect the economy when running on LPG as well as on petrol?
Kind regards,
Mike.
Running the car on LPG shouldn't have any effect on the lambda sensors. As ainars says, replace them with new ones, as the pre-cat one's are a pain to get at (and you don't want to put a second hand one in only for it to fail soon afterwards). Admittedly, I did mine on a 3.7, so assuming the 4.2 layout is very similar.
BTW The only issue I ever had with running on LPG was about six months after I got the job done, as it kept reverting back to petrol. Was told at the time it was a faulty coil pack, but having experienced another faulty coil pack recently, I'm doubting that explanation now.
