The limit is 1.6mm deep across the central 3/4 of the tyre, so, in theory, if the rest of the tyres meet this requirement, then it should pass.
However, chances are you'll get an advisory because of the outer wear. The question is how bad is the wear on the outside? Has the tread pattern disappeared yet, or worse still, can you see any of the carcass? Then you're looking at a fail.
There is also the human element in it as well, as to how strict the tester is on the day.
UPDATE: Decided to see if I could find anything online about 'legal' requirements and came across a very interesting statement. Check out the following page (from the official MOT guidelines):
https://www.mot-testing.service.gov....#section_5.2.3
It's quite lengthy, so search for the word 'bald', and you will come across the following statement:
Either side of the central three-quarters of the tyre can be devoid of tread (‘bald’).
I've read and re-read that section on 'tread depth', and I still come to the conclusion that the above statement would mean that your tyres 'should' pass (subject to there not being any damage or carcass showing). Don't take my word for it though. Read through it and see what you make of it, and if in doubt, either change the tyres beforehand or print out that section of the guidelines and take it with you on the day.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
