You can do it, but you will need access to VCDS (Carista or ODBeleven may work, but I can't confirm).
Within VCDS, go into module
46 - Central Convenience. Click on
Coding, and you will presented with the following screen, as well as a pop-up hint window. Make a note of the existing value you have (e.g.
0005885 in my case, which has it enabled), and then add
1024 (Anti-Theft Warning System Confirmation via Horn) to it. Then click on '
Do It!', and then exit out of VCDS as normal.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
