The first time I got Vod on the lift I could see the telltale pink stains which are indicative of a failed oil cooler pipe
Is it worth doing this whilst doing the timing belt change, even if the existing pipe is not leaking? On the Audiworld site, it says it takes around 7 hours, which seems an awful long time.
O-rings? The pipe has four grooves, but the Audiworld site seems to only show two being used on the pipe and one on another part. It also mentions another o-ring they suggest replacing.
This is the bit that has me confused:
3 each O rings, part #077-121-437.
1 each oil seal/gasket, part #077-115-441.
I've provided a link to the page in question below:
http://www.audipages.com/Tech_Articl...reinstall.html
Where do you get the o-rings from? I'm finding dealer prices of £7 each, so was thinking of just buying a metal pipe with o-rings provided instead, like this one:
https://www.ebay.co.uk/itm/273203362499
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
