Old 1st March 2020, 01:45 PM
Originally Posted by C4R 100N View Post
If I push the car, am I right in thinking that I won't be able to steer it very well and that the brakes won't work? It is a slight downward journey to the driveway then a sharp right and then a bit of an uphill push to the carport. How many 'friends' do you reckon it will take? Thanks for the suggestion by the way.
Not sure about access around your carport, but it might be safer to tow it with a solid bar, as trying to stop a two ton car going downhill that has no brakes or steering may lose you a friend or two.
