Old 10th October 2020, 10:25 AM
You don't mention whether or not you went for a drive after you re-initialised the tyres. If not, then that would be the case as it requires driving for 5-10 minutes before they show the pressure.
As for replacements, someone on one of the Facebook groups was asking a similar question and I provided the following link (not affiliated to it). It's for a set of four TPMS sensors plus the all important programming pad (which is never mentioned in the other TPMS ads), as without it the sensors are useless. You just need to make sure and program them the same as your existing ones, including the correct frequency.
On the build sticker, you should have either 7K3 (433MHz) or 7K4 (315MHz).
https://www.ebay.co.uk/itm/133417324862
