Old 21st June 2021, 01:42 PM
Loosen the crimped ring from around the front bezel then lever the bezel off the housing and the assembly will split in to two parts with the spring between them.
Since posting, I had another look at the photos and deemed it necessary to remove that crimp ring. However, it seems I'm not 'levering' enough. At least I was on the right track.
