View Single Post
Old 30th September 2021, 05:15 PM
Originally Posted by GlynH View Post
The consequence is the arse-end of the 7F intrudes into the top rear of the boot space and of course the rear boot panel trip that covers the electrics won't fit back in place.
Obviously Audi wouldn't leave it like this and I was wondering what the factory solution looked like?
No personal experience of the D4, but this should help. Looking at the images of the boot panel, I'm making the assumption that the unit is placed above where the fridge would fit. That being the case, then the following image should help.
Item 65 is just referred to as a 'cover' but is only applicable to cars with Multimedia in the rear compartment. The part number is 4H0863688A and costs less than £20 new.
As for the back panel, the other two attached images show the two main different versions, one with and one without a section cut out of it. Trim 1 is likely to be what you have, with Trim 2 being what you need. There are also different variants depending on whether the ski hatch or fridge are fitted.
Name:	A8 D4 Boot Trim 1.jpg
ID:	27245   Click image for larger version
Name:	A8 D4 Boot Trim 2.jpg
ID:	27246   Click image for larger version
Name:	A8 D4 Boot Trim.png
