Originally Posted by Garry1
Checked the boot and some water in the wheel well
The boot lid had water in it
Also car has no sunroof carpet is dry inside
Also date and time in the car is 2003
Three things:
1. Water in the boot lid is most likely a result of water ingress through the light clusters, as over time the seals perish and in some cases the outer lense covering also start to separate from the rest of the unit.
2. Two other possible sources of water ingress are due to blockages in the a/c drains either side of the transmission tunnel and also blocked drains in the plenum chamber. These have been discussed on the forum.
3. If that is the case, it makes sense to correct the date and time so that any errors generated will have the correct date/time, as it's essential to know when it happened. Also, three of the dates in the second scan are after 2003, so this just results in confusion as to what happened and when.
My course of action would be as follows:
. Sort out the date/time
. Go through the process shown in the video to see if the group of modules (07 etc) are selected
. Perform a scan
. Go into each module that has thrown an error and attempt to clear the codes
. Note down any module number that fails to clear the codes
. Go for a drive
. Rescan car
. Post scan along with details of any modules that failed to clear codes as performed above
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
