Originally Posted by Garry1
Unsure what I have done
Changed the amplifier and it worked for a couple of mins then shut down
Two things.
1. The amplifier has component protection, so that needs removed before it will operate properly. I believe the symptoms you mentioned is what happens with CP active. This is of course assuming that when you say you 'changed' the amplifier, you put in another one.
2. When clearing the error codes, did you clear them one by one; i.e. going into each module and clearing them; or did you just select the 'clear all DTCs'? As good as VCDS is, one of it's downfalls is that the 'clear all DTCs' doesn't always do what it is supposed to. Using this latest scan, can you go into each module that has error codes and try and clear them, and note down which modules don't clear. Then just list the module numbers that still have errors. e.g. 01,46 etc (01 & 04 will definitely not clear). One final point. Is the TPMS warning light on in the instrument cluster?
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
