View Single Post
Old 29th January 2023, 04:08 PM
Originally Posted by GlynH View Post
Did either of you make any progress on this?
Reason I ask is because I fitted all the hardware some time ago and am only now just getting around to the wiring side of things.
If you need any wiring details I do have some here I've pulled together from various sources and my original thread can be seen here;
http://forum.a8parts.co.uk/showthread.php?t=13946
You mentioned in your other thread about having some of the wiring details. The attached PDF is the current flow diagram for the RSE system if it's of any help, although you may already have it.
File Type: pdf A8 D4 Rear Seat Entertainment - Current Flow Diagram.pdf (573.5 KB, 952 views)
