Old 6th February 2023, 09:11 AM
Check posts #9 and #10 in the following thread. The thread is about the D3 but post #9 references the D2 and includes photos. Use a multimeter to check resistance on the two sensors. Post #10 mentions a contact cleaner for the airbag connector block:
https://www.audiworld.com/forums/a8-.../#post24456884
"N201 Rear side airbag igniter, driver's side" - This is what the current flow diagram gives for N201, but I think "driver's side" in this instance refers to LHD vehicles. MJ will confirm, but odd part numbers are 'left' side and even part numbers are 'right' side, irrespective of LHD/RHD.
Just found the following in the current flow diagram, which would rule out curtain airbags:
N251 Curtain airbag igniter, driver's side
N252 Curtain airbag igniter, front passenger's side
I got these from the following PDF in the D2 Tech Dump thread:
Current Flow Basic equipment From model year 2001.pdf
