5th March 2023, 09:11 PM
Originally Posted by Julian Thompson
but from there it won’t accept anything in the soft coding section to do with Brembo brakes.
There is a specific sequence of tasks when coding the ABS, as demonstrated in the following video. Is this the same sequence you followed, bearing in mind that the codes you need will be different, as the video use an A4? If you have, that will at least confirm what matty mentioned:
https://www.youtube.com/watch?v=G7YRiVYrLjo
