Old 18th March 2023, 05:29 PM
Found similar posts elsewhere and two stood out that you might already have seen. You've checked the wiring at the connector end and the connector itself, but I saw these the following comments that are worth investigating, both being broken wires:
I was able to fix my issue with N111, wire was pinched in the wheel well.
1st time I removed the sheild and the compressor as mine was broken way up where it goes into the main loom.
Also worth doing a resistance check as mentioned in this post:
https://forums.ross-tech.com/index.p...71/post-256551
