Old 21st September 2023, 09:34 AM
Originally Posted by Toblahoe View Post
Good point on the voltages, I will check more thoroughly with voltages at the fuses, and I've also been advised to check J644 - Energy management control unit.
Something was nagging me about the 'over voltage' errors and how all this started, so reread your first post. In addition to checking the J644/BEM module, it might be worth using VCDS to check the output from the alternator. Having said that, apparently with the D3, the BEM can control the output from the alternator, depending on load, so it may well be the BEM.
I did some searching and couldn't find anything about voltage spikes in the D3, but came across one for the D2 where they said a voltage spike threw the transmission into limp mode. Just wondering if that was the 'jerked/jumped' situation you experienced. Unfortunately there was never an update to the thread, as to their final solution: https://forums.quattroworld.com/a8/threads/8526.phtml
