Thread: ABS Fault !!!!!
Old 26th September 2023, 11:21 AM
Originally Posted by donp38 View Post
If not fixed then.
Step 2 : VCDS sequence..
However....I assume VCDS will tell me what to do and when?
Many thanks..
I haven't used that option, but the following post gives instructions (which I believe VCDS prompts for):
https://forums.ross-tech.com/index.p...79/post-220317
However, as MJ mentioned in the post I linked to earlier, this is only required IF the ABS pump was completely drained or somehow got air in it, and this bleed process is done through the front callipers only.
You mention the squelch from the ABS pump. Just to confirm, are you hearing it from the ABS pump area or from the brake pedal area inside the car? Can you upload a video of it, as it might help others diagnose the issue.
