Old 28th September 2023, 12:39 PM
You could try shorting the pins on the connector to shut it up while you order a replacement.
Originally Posted by Mossyboy1978 View Post
I haven't actually. I need to get a voltmeter and see if there is current.
Question is - if there isn't, where does that wiring go back to that might need to be checked? Fusebox? ECU?
Have you tried MJs suggestion of shorting the pins on the connector? i.e. short pins + warning disappears = wiring okay
