Originally Posted by Mossyboy1978
Why would I need an extra length of wire for the green/yellow wire test? Sorry - I am an auto electrics noob....
Also - is there a way to check the connection at the pin? could it be that simple?
I'm assuming that connector is behind the instrument binnacle? Could be as simple as a wire come out I suppose?
For a continuity check of the wire, you need to have a probe at either end, as it's measuring the resistance between the probes. One end will be at the coolant tank where the connector is located (your photo posted earlier) and the other end will be at back of the instrument cluster (wires attached to grey block in following image).
In terms of a wire coming out, I would tend to think it wouldn't happen at the instrument cluster end, but there could be a possibility that the connector at the coolant tank end might be further back in the connector than it should be. i.e. whilst being connected, one of the pins was pushed further back, so not making a connection. However, having said that, it doesn't explain how it happened in the first place.
My DIY jobs -
Replaced alarm horn,
Replaced Coolant Temp sensor,
Updated RNS-D firmware,
Installed Reversing Camera and Digital TV,
Dashcam Installation,
Retrofitted Rear Blinds,
Auto-Dimming Rear View Mirror,
Chrome Boot Struts
Sold!
2008 S8 D3 5.2 V10 - Engine: BSM, Gearbox:KLW, Colour:LY7F Suzuka Grey Pearl Effect, Interior:Black/Black with Silver/Black valcona leather with carbon atlas inserts, Bang & Olufsen, Heated windscreen, Soft-close doors, TV, DAB, AMI, Quad Zone, Auto Boot, Auto dim Mirrors, Keyless entry, PDC with rearview camera, AFS II Headlights
My DIY jobs -
Fan Jet Windscreen Washers,
Retrofitted Electric Side Blinds
