Old 5th March 2024, 09:17 PM
Originally Posted by donp38 View Post
Anyone with Pt numbers? I can see there are some differences...
You don't mention exactly what D2 you have, so I'm assuming it's a FL D2 S8 since you've posted in this particular thread. With that in mind, part numbers are as follows:
Front
Disk - 4D0615301B 345x30mm B- Brembo
Pads - 4D0698151L - pair
Rear
Disk - 8E0615301B 280x22mm - PR Code 1KW (this is the bigger of the two disk sizes)
Pad - 1J0698451H - pair
It would help a lot going forward to add your car specs to your signature line, in case the above information doesn't apply.
