I've more questions for you than answers.
1. Are you using a registered version of VCDS or a cloned version?
2. Why are you trying to access the Immobilizer module?
3. Why are you trying to access the Instrument cluster, which on the D2 is Address 17?
4. What other functions in VCDS are not available?
5. What type of 'map' are you referring to? Navigation - It's a CD in the RNS-D / Software module map - didn't think Audi would offer the facility of downloading maps from them.
6. Can you give us some history as to why you're doing this now?
7. Have you had the car for a while and it has just started having problems?
8. Have you just purchased the car and was it driving okay or did it have problems?
9. What if any symptoms are you experiencing with the car that's making you ask the above questions?
10. Are you able to do a full scan of the car with VCDS? Can you post it here? If there are errors, have you tried clearing all the errors, driving the car and then scanning it again to see what ones reappear again?
