Originally Posted by Horrgakx
Although the ARB drop links might be a good shout, I'm not 100% on board with that. Although the noise could be as a result of ARB drop links as the noise happens with sudden vertical movement (I recorded the sound and will post later), but would they be the cause of the bad jerking / lurching?
I somehow missed the lurching part. With that said, I just came across a thread using the same term, but unfortunately no resolution in it. Link as follows:
https://www.audiworld.com/forums/a8-...issue-2876581/
I also forgot to include the link to the other thread regarding the grating noise:
https://www.audiworld.com/forums/a8-...links-2881584/
Ps - the diagram you posted is one of a possible two sets. The only difference I can see between the two is the inclusion of a vibration damper. But i cant see what links the appropriate drawing to the vehicle...?
The second set that you're referring to is for the armoured version of the car. The first set is for every other variation, regardless of engine. Stupidly, I provided the image of the armoured set, which I've now changed, but the part numbers are correct for yours.
