View Single Post
Old 14th July 2025, 08:52 AM
Originally Posted by Horrgakx View Post
Csn I ask what you did with the wire though? The sensor looks like it comes complete with wire and plug at the other end. I think it goes into a bank of plugs somewhere under the right side airbox...?
The OP can't respond as they were banned several years ago. The O2 sensor does indeed come with a plug on the end. In terms of the question you asked, and location, I've already detailed this in your other thread:
https://forum.a8parts.co.uk/showpost...19&postcount=6
If you use the PDF as instructed, it also shows where the individual sensor wires go to, and their route. Even without that, all you have to do is lay out the new one along the same route before removing it at either end.
