Old 1st November 2018, 08:24 PM
Default What's in the workshop? A 3D printer!
Ok, so its in the kitchen, but I thought I'd stick to the theme
Frustrated by the declining availability of genuine parts, I decided to start making my own, and to that end I bought a 3D printer - a Creality CR10-S
This is a Fused Deposition Modelling (FDM) machine. It takes plastic filament, melts it in a mobile print head, and lays it down a layer at a time to build a solid object. Obviously the first thing I printed was a cat
It lasted four days before I voided the warranty I changed the cheap original fans for some quieter ones
I then set about printing a few upgrades for the printer. I love that it can make its own parts! This filament was supposedly aubergine. It turns out more like pink, but it makes a pleasing contrast to the black anodised aluminium so I don't mind.
I then printed an army of calibration cats while dialling in the settings on the machine
ID:	20329   Click image for larger version
ID:	20330   Click image for larger version
ID:	20331   Click image for larger version
ID:	20332   Click image for larger version
ID:	20333   Click image for larger version
Old 1st November 2018, 08:38 PM
Once I'd got the printer working nicely I had a go at making something useful. I made this design in Tinkercad which is a free online 3D cad program.
Laying the design down
Done
Took apart a USB cig lighter charger
Took apart the D2 cig lighter
Mounted the USB sockets in the printed parts and then mounted that assembly in the cig lighter surround
USB charging points instead of a cig lighter
ID:	20346   Click image for larger version
ID:	20347   Click image for larger version
ID:	20348   Click image for larger version
ID:	20349   Click image for larger version
ID:	20350   Click image for larger version
ID:	20351   Click image for larger version
ID:	20352   Click image for larger version
ID:	20353   Click image for larger version
ID:	20354   Click image for larger version
Old 1st November 2018, 09:00 PM
Made some parts to fill in the holes in the air box after removing the secondary air pump.
These two pieces snap together to fill in the hole from the air hose and electrical connector.
and these plugs fill in the bolt holes
A bit of adhesive for extra security
Fitted in place
ID:	20358   Click image for larger version
ID:	20359   Click image for larger version
ID:	20360   Click image for larger version
ID:	20361   Click image for larger version
ID:	20362   Click image for larger version
ID:	20363   Click image for larger version
Old 1st November 2018, 11:06 PM
What size of items can these print to, as all I've ever seen produced from 3D printers seems to be small trinket sized items, like your cats? Really thinking about the printing of the D2 foglight grilles, as was mentioned elsewhere.
Will you be having a "What's cooking in the kitchen?" thread, where we have to guess what the mystery printed object is for?
Old 2nd November 2018, 07:41 AM
I've been doing that on Facebook
This machine has a print bed of 300x300mm so it won't do a foglight grille in one piece, but there are bonding agents for many of the printable materials which are as strong as or stronger than the material itself so its entirely feasible to print them in two pieces and bond them together. It would do a two-piece grille ok though.
I think I mentioned in the other thread that the challenge with the grilles is getting a good enough surface finish on them, and that's going to take some experimentation. I have some carbon fibre reinforced material which prints with a nice satin-sheen finish, but I don't know how durable it is, and its expensive. ABS can be vapour-smoothed with acetone, but its difficult to print and would leave a gloss finish so that would need painting to match the factory look.
Plus of course we still need to scan them in and manipulate the scan in to something printable.
Tbh the grilles project wasn't the primary reason for buying this machine - its more of a future aspiration at this point. Its main use is printing smaller functional parts like clips and brackets which can't be bought from Audi any more, such as the clips for the radiator breather pipe or the starter junction box. Maybe even door card clips, although that's a bit of a stretch but worth a try. Radio adapter plates too.
Oh, and the brake master cylinder brace which I will post up shortly
Old 2nd November 2018, 08:40 AM
Cool
So do you have access to a 3D laser scanner to scan the original parts MJ?
A 3D printer is something I've been meaning to buy for a long time. I've been waiting for the technology to evolve more, but I'm also waiting until I have a bit more free time, because I will no doubt become completely engrossed by it just as soon as I get one.
Have you seen Carbon's 3D printing technology? I think it's only a matter of time before this level of 3D printing becomes affordable and commonplace:
https://www.carbon3d.com/
https://www.youtube.com/watch?v=zXE-icw28n8
https://www.youtube.com/watch?v=O2thSsQrZUM
Old 2nd November 2018, 09:22 AM
I don't have a scanner yet, but I'm planning to contrive one from an Xbox kinect
The Carbon stuff is very very cool indeed. I was using resin stereolithography 25 years ago to make prototypes of injection moulded parts. They were brittle and fragile, and took many days to make anything useful. No one had even thought of the term '3D printing' at the time. Now you can make production parts using essentially the same technique.
Thanks to open source software to drive them, the technology has evolved to the point where a desktop FDM printer is <£200 (mine was £350) and can make entirely usable things of remarkable quality. I printed this from wood - essentially MDF filament:
It is totally engrossing too. I can sit there watching it make things, listening to the stepper motors singing, for far longer than necessary!
Old 2nd November 2018, 06:25 PM
Regulus Regulus is offline
Very cool stuff MJ
Looking through the list of items you have made so far. I would guess you will be able to make the headlight bracket arms too?
https://www.ecstuning.com/b-genuine-...d0998121a~oee/
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Ok the brake master cylinder brace that a few of you guys have been waiting for
I had noticed when working on the manual swap that the brake fluid reservoir moved around an alarming amount when I stood on the brake pedal. It seems from the 'brake block' thread that I wasn't the only one, but there's nothing on the market for this any more so I decided to make my own.
Vid of the unsupported master cylinder here
Started off with a cad model in Fusion 360:
Printed it in the aubergine filament
Installed:
I took a video of this one installed and it didn't actually do much because the whole assembly is mostly rotating around the top bulkhead where the pedal box is mounted rather than pushing forwards. This brace stopped it moving forwards, but didn't prevent the master cylinder lifting up. So, a few modifications to the model resulted in this:
Printed one in some cheap red PLA
Tolerances weren't good on this so I tweaked the dimensions slightly and printed in some better material
This one works pretty well as you can see here
ID:	20370   Click image for larger version
ID:	20371   Click image for larger version
ID:	20372   Click image for larger version
ID:	20373   Click image for larger version
ID:	20374   Click image for larger version
ID:	20375   Click image for larger version
ID:	20376   Click image for larger version
ID:	20377   Click image for larger version
ID:	20378   Click image for larger version
Old 2nd November 2018, 06:26 PM
Very cool stuff MJ
Those are on the list
