Old 17th November 2022, 08:23 AM
cammmy cammmy is offline
Default Footwell Heater
Hi All
I've seen reports that the electric heating unit in the rear footwells is a common issue. Do we know what the actual failure is and if it's repairable Vs replacing with another unit destined to fail at some point?
'06 D3 A8 L 4.2 TDi
Old 17th November 2022, 10:57 AM
They are indeed a very common failure issue on the D3. I replaced both of mine when I had the S8 with secondhand ones, and decided to dismantle the old one. Basically all it consists of is a large heatsink with four transistors bolted to it, with the heat from the transistors being dissipated by the heat sink, and with some air blown through them you get a very basic heater. It's all held in with some sort of epoxy, so you'd end up destroying the outer part trying to get the heat sink out.
Old 17th November 2022, 01:14 PM
Cool, thanks. I'll have a go in the near future. If they're dead then there's nothing to lose. You didn't take any pics did you?
'06 D3 A8 L 4.2 TDi
Old 18th November 2022, 12:17 PM
Unfortunately not. However, I did come across this image of a dismantled one:
https://www.audiworld.com/forums/att...s-dscn1955.jpg
