Old 8th December 2022, 09:18 PM
monkeyboyuk monkeyboyuk is offline
Default Annoying electrical fan from behind dash
So just the other week i started getting an annoying fan noise from in behind dash when I start up my car (pf d2 4.2q sport). Randomly cuts out for a few seconds every so often, then chimes right back in again until engine switched off.
Any ideas where to start
Old 8th December 2022, 09:31 PM
Is it definitely a fan noise or a clicking noise for several seconds, stops for a while and then repeats? If the latter, it will be one of the actuators that direct the air from the HVAC system.
Old 9th December 2022, 06:16 AM
Or perhaps the aircon compressor? Does it stop if you turn the aircon off?
Old 9th December 2022, 06:49 AM
Definitely a fan and not just a clicking. When it stops it’s just for a few seconds, then starts again
Think I tried switching the air con off too, and made no difference, but will check again this morning
Old 9th December 2022, 08:12 AM
So two possibilities ruled out. Next suggestion is fan bearings. Checkout the following page, and if you have access to VCDS or other diagnostic tool, there is a check you can run:
http://www.audipages.com/Tech_Articl...anreplace.html
Old 9th December 2022, 08:13 AM
Could be the blower motor in the colder weather.
Does the noise the vary or go away if you manually adjust the fan speed ?
Old 9th December 2022, 08:16 AM
Thanks will hook up vcds and see what I get. Haven’t done much on d2 with it used it more on my d3
Old 9th December 2022, 08:18 AM
No just a constant with the random stops I mentioned. Changing blower speed etc has no effect on it
Old 9th December 2022, 10:07 AM
How about the dreaded auxiliary coolant pump motor starting to fail?
Old 9th December 2022, 12:24 PM
That ^ or the cabin temperature sensor inlet fan, which lives in the centre console above the hvac controls.
