Old 5th May 2016, 03:34 PM
Default Need help finding plastic clips
My front undertray, the big flat panel that goes rearwards from under the front bumper, is coming adrift. Not sure if that's what it's called though.
I think it's been missing a few retaining clips for a while and catching it over a kerb hasn't helped either.
I can see that some clips are loose or missing from underneath and also where it joins the front lower edge of the wheel arch liners.
There also seems to be a couple of the (same/similar?) clips missing from the wheel arch liners.
I presume these are mushroom-shaped retainers with some sort of central peg that is pushed in after fixing to make it secure.
Does anyone know the Audi or VAG part number, or whether generic trim clips can be used, if so what type and size?
