Hi everyone.
Could you help me with this hybrid TV problem please. My car has a fitted analogue TV. From what I've researched for my particular A8, hybrid tuner part number, 4E0910148 - A,B,C,D, or E should be ok......I think? So, I acquired a hybrid TV: 4E0 910 148 C. It came off a 2007 S5, and the seller said it was in perfect working order. Time to test it. Left boot setup with nav player already out. Radio tuner(?) in front, TV module behind it and DSP amp to the left, behind the silver metal carrier. Removed the radio tuner to bring the cables out a bit more. Then took all plugs out of analogue and put them in the hybrid. The brown & green aerial plugs don't push in as far on the hybrid as with the analogue. This is the MMI screen with analogue TV fitted. ......and this is what I got with the hybrid. The hybrid shows up in VCDS but not on the MMI screen. VCDS scans of analogue and hybrid: Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 C HW: 4E0 919 146 Component: TV analog TUNER H12 0210 Revision: 00000001 Serial number: 00000000003067 Coding: 0001003 Shop #: WSC 00000 785 00200 VCID: 211FE2479DC914935CC-8074 Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 C HW: 4E0 919 148 Component: R0078 TVhybridTuner 0400 Revision: R0H06000 Serial number: 76300800568601 Coding: 0000203 Shop #: WSC 06325 000 00000 VCID: 2313E84F87D506834E0-8076 Took some screenshots, but I don't pretend to know what it all means: In VCDS on the hybrid screen, I clicked on coding (I think?), and a little box came up asking me to confirm coding, then it said 'coding accepted'. Still nothing came up on the MMI screen. Connected all the plugs back in the analogue tuner and the normal CD, TV AV 1 & 2 came back up on the MMI screen. VCDS also showed the analogue TV back at address 57. Put everything back together in the boot and went for a pint..........yeah right ![]() Any ideas anyone? If so, please tell me in 'baby steps' ![]()
From what I can tell from the pics, you have Rear Seat Entertainment in your car?
If I'm reading the coding for your analogue tuner correctly, it's: 000 - all good 1 = RSE fitted 0 = A6/A8 model coding 03 = UK At the moment it looks like the hybrid is coded for: 000 - all good 0 = NO RSE fitted 2 = model code, so presumably for A/S5 03 = UK So basically you need to tell the TV module what the spec of your car is, so that it relays the right information for the MMI to pick up (assuming this module is actually compatible with your car) It's unlikely to show anything on the MMI until the module is coded correctly ETA - so in very basic terms, you need to copy that coding string that you use for the analogue tuner, and enter the same into the 'software coding' box, and click 'do it'. The little pop up box should guide you - wherever the ? appears, it's basically giving you a guide to which digit relates to which function from that list - hopefully explained as I've posted above
===SOLD===2002 Audi S8 D2 Final Edition (yes, really) in Avus Silver with purple extended leather===SOLD=== 2011 S5 Sportback in Phantom Black with black Super Sports leather, 9x20s, tech pack high, adaptive xenon plus, intelligent key, memory seats pack, sunroof, B&O, Audi Drive Select & quattro Sports Diff, DAB, parking system plus 2015 VW Golf GTI Performance Pack in Carbon Grey with black Vienna leather, tech pack (Discovery Pro nav & Dynaudio), DCC, factory towbar and retrofit RVC Last edited by Adrian E; 26th February 2021 at 07:10 PM. |
So, I put in: 0001003 Is that right Adrian?
Also, do the antenna outputs look ok?
Number 4 seems a bit iffy.
If you don't have RSE then the code would be 0000003.
Did VCDS throw up an error for antenna 4? Just curious since the output test shows it as 'deactivated'. BTW The part you have; 4E0910148C; is fine. The A8 will accept A,B,C and E.
Got no idea why the 1 for RSE is there, I've never messed with the TV at all. No error for antenna 4. Is it possible to activate it? Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 C HW: 4E0 919 148 Component: R0078 TVhybridTuner 0400 Revision: R0H06000 Serial number: 76300800568601 Coding: 0000203 Shop #: WSC 06325 000 00000 VCID: 2313E84F87D506834E0-8076 No fault code found. Ah, so I got the right part number then. Well that's something then ![]() Do you think I need to upgrade the MMI software/firmware for this to work. It's the original 2004 SW:07.7.0 Thanks.
There is no recoding needed to go from analogue TV to hybrid.
It is a straight swap over. However. Hybrid TV didn't exist in 2004, so, unless you have updated your MMI to the latest 5570 version, it simply won't understand what the device is that you have plugged into the MOST bus, so it will ignore it.....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
![]() Time to commence battle with HAL 9000 then. I'll report back on the outcome. On a brighter note. The number 4 antenna has decided to come out of lockdown.
So, just to be sure
![]() When the MMI is updated, which is the correct code for the hybrid tuner? 1. 0001003 = The original analogue tuner code. Although, I have no RSE. 2. 0000003 = The original analogue tuner code, omitting the RSE '1'. 3. 0000203 = The code that's already in the hybrid tuner. Thanks.
