Old 22nd April 2019, 08:16 AM
Default What's in the workshop this weekend? . . . General VOD
Well, I bought another one This one literally saved from death with not a moment to spare! A friend has a unit on a scrap yard, so when a D2 rolled in, he called me straight away. FL1 3.7 Quattro, sport seats, blown gearbox. "I'll be there in 2 hours"
£600 later, I had this:
A one-owner 3.7 quattro, with sport seats (not a Sport model mind). It was bought new at Exeter Audi as a company car, and then at the end of its company service was bought from the company by it's driver and kept by him until about six months ago when the gearbox failed at 117K. It appears to have had the same private plate from new until it was disposed of.
I could tell as soon as I opened the door it had suffered some serious water ingress - it smells like a locker room and there is mould all over the place. Still, a decent haul of parts for the money. At least, that was the plan
I got VCDS on it to read the gearbox codes and see just how exploded it was, and curiously there were no 'incorrect ratio' codes normally associated with a blown 5HP19, just loads and loads of sensor and solenoid failures. The ECU was the same - it had three pages of codes , and the ESP unit also had half a dozen. I immediately went under the bonnet and opened up the electronics box to find it dripping wet inside Could it really be this easy...?
All the ECU codes cleared fine, as did a couple of TCU codes once I'd cleaned up all the body harness connectors. I had a spare FL ESP unit so I just swapped and recoded that, and that was also fine. I didn't have a spare TCU of the right code though, so pulled that out and opened it up...
Oh dear! Still, I had some time so I got out the isopropyl alcohol and a toothbrush and got scrubbing.
After an hour of it sitting on a hot radiator I put it back in.
Result! It drives absolutely fine, and no more drivetrain fault codes. It really was that easy
To celebrate, I gave him a bath and named him General Vod
Only two minor bits of body damage
Of course now he's working and has a name, he can't be a parts car any more can he?
ID:	21439   Click image for larger version
ID:	21440   Click image for larger version
ID:	21441   Click image for larger version
ID:	21442   Click image for larger version
ID:	21443   Click image for larger version
ID:	21444   Click image for larger version
ID:	21445   Click image for larger version
ID:	21446   Click image for larger version
ID:	21447   Click image for larger version
ID:	21449   Click image for larger version
ID:	21450   Click image for larger version
ID:	21451   Click image for larger version
ID:	21452   Click image for larger version
Old 22nd April 2019, 09:36 AM
Well that has to be the shortest "What's in the workshop this weekend?" thread ever, but great to see another D2 saved from the crusher.
Old 22nd April 2019, 09:38 AM
I'm not finished yet
Old 22nd April 2019, 09:53 AM
homer simpson's Avatar
Amazing how some people just simply can't be bothered to find out what is wrong. When there is obvious water ingress then it is highly likely to cause issues. Having said that, it gives opportunities for others (MJ) to buy them cheap with an 'easy' fix.
Well done MJ, you deserve some easy ones, although as you have said, 'this one isn't finished yet'!
Old 22nd April 2019, 10:28 AM
The crazy thing is that it's already had a gearbox rebuild at some point! I guess it must have been out of warranty so when it started having problems again they just bailed on it rather than investigating.
This is my hit list prior to MoT on Tuesday:
Not on the list is 'remove swimming pool from driver's side carpet' and valet the interior so it doesn't smell of old socks
Old 22nd April 2019, 11:17 AM
Nognar Nognar is offline
Good work and it’s just so important to keep as many good D2s on the road
Old 22nd April 2019, 12:31 PM
Would you not replace both front springs as a pair?
Old 22nd April 2019, 01:25 PM
Nice save
What's your plans for the car? Courtesy car perhaps, for when those of us who don't have another vehicle need to leave our cars with you?
Old 22nd April 2019, 01:51 PM
If I was fitting new, yes, but I have a used one of similar mileage and the name of the game at the moment is to pass the MoT for as little outlay as possible. After that I'll drive it around and iron out the bugs and then decide what to do with it.
Nice save
That is one potential option
Old 22nd April 2019, 03:48 PM
Good point. I forgot that (a) it wasn't a customer's car and (b) you probably have one lying around!
I should have known better than to question it
