Old 30th March 2019, 09:42 PM
Default What was in the workshop last week? Stephen's black Final Edition
I'm a bit late on this one since I just ran out of energy to do the thread while I was doing the car.
Stephen (Tintin) brought down his gorgeous black FE for a few jobs, namely fitting a Milltek exhaust, doing cam belt, engine service and tensioner pads, and a bit of interior fettling.
This is the task list:
The first challenge though was opening the bonnet, as the cable had snapped! With that done, I then set about removing 3 litres of rain water from the rain tray due to blocked drains.
In the process the sucky tool pulled out all sorts of gunge!
The usual build up of leaves and schmutz
Definitely something wrong here!
Someone has been in here before as the clips were all broken and the cables all routed the wrong way
A8parts supplied a replacement cable and I routed it the correct way
New cable ties in the wing
fixed in place with the proper fitting
Now on to the actual work
ID:	21023   Click image for larger version
ID:	21024   Click image for larger version
ID:	21025   Click image for larger version
ID:	21026   Click image for larger version
ID:	21027   Click image for larger version
ID:	21028   Click image for larger version
ID:	21029   Click image for larger version
ID:	21030   Click image for larger version
ID:	21031   Click image for larger version
Old 30th March 2019, 09:50 PM
The passenger seat thigh bolster had come adrift
The seam which holds the leather to the base had just popped out so simple to fix with the seat out of the car
Remove two circlips and the thigh bolster slides off its mounting rails for easier access
Tuck the seam back in to the slot
Done
All back together
Someone had butchered the dash panels I didn't have time to fix this so I'll get this on the second visit.
As there had been a fair bit of water ingress I removed all the seats so I could run the dehumidifier inside while I was doing the mechanical work. It was also easier to clean and condition the luscious red leather while it was out of the car
ID:	21033   Click image for larger version
ID:	21034   Click image for larger version
ID:	21035   Click image for larger version
ID:	21036   Click image for larger version
ID:	21037   Click image for larger version
ID:	21038   Click image for larger version
ID:	21039   Click image for larger version
ID:	21040   Click image for larger version
ID:	21041   Click image for larger version
ID:	21043   Click image for larger version
Old 31st March 2019, 12:05 AM
I've had this on my D2. I think some people just rip off these panels, and then find out afterwards how they're attached.
Looking forward to seeing Herman in all his red glory.
Old 31st March 2019, 08:44 PM
The perpetrator of this mess actually stuck the broken part to the back of the panel with masking tape for someone else to fix later
Next job - find out why the ECU won't communicate with VCDS. No continuity between the body harness and ecu connector...
Well, there's your problem! I unwrapped the engine harness and this wire just broke when I touched it.
Look at the bulges in the insulation! This wire, somehow, has corroded from the inside out. These bulges are all along its length apart from an inch at either end, so the water hasn't got in from the ends. It's been absorbed through the PVC jacket, but only this wire! All the others are perfectly fine
Cut out the bad wire and spliced in a new piece
Comms re-established, I wrapped the harness up again and put it all back to bed
ID:	21049   Click image for larger version
ID:	21050   Click image for larger version
ID:	21051   Click image for larger version
ID:	21052   Click image for larger version
ID:	21054   Click image for larger version
ID:	21055   Click image for larger version
ID:	21056   Click image for larger version
ID:	21057   Click image for larger version
Old 31st March 2019, 09:11 PM
RS6's Avatar
RS6 RS6 is offline
Good grief thats in a state loads of problems there!
Excellent work
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 31st March 2019, 09:27 PM
Well done Doctor
Good fix
Old 31st March 2019, 09:38 PM
RICKY D's Avatar
RICKY D RICKY D is offline
I’m in awe of your work MJ.
Another great thread
Old 1st April 2019, 12:07 AM
H-M3 H-M3 is offline
Someone knows their SH##! Sorry that’s the only way I could express.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 1st April 2019, 06:35 AM
Spanker's Avatar
Spanker Spanker is offline
We all love these posts.
Not all of us may comment but we all love them. Especially when our own cars have been in this situation.
Dean
Old 1st April 2019, 09:03 PM
On to the tensioner pads. Front end off and locking tools in.
Removed the coil packs and wiring harness to get access to the cam covers
Started on the passenger side
Whenever I'm working on an engine with the belt off I cable-tie the locking bar to the cams so they can't move. The passenger side has a habit of jumping round 15 degrees when you're not watching!
Spotless inside This engine has been dealer-serviced to this point and fed almost exclusively on V-power or Momentum fuel and it obviously likes it. I've never seen an engine this clean inside (apart from my brand new one).
Still an oily mess on the outside though
New pads in place
Ready for the cover to go back on with a new gasket
That side done
Even in a spotless engine, the pads are still worn - the #1 cause of premature engine failure in D2s. Shown above the pad, the #2 cause - the hydraulic belt tensioner.
ID:	21101   Click image for larger version
ID:	21102   Click image for larger version
ID:	21103   Click image for larger version
ID:	21104   Click image for larger version
ID:	21105   Click image for larger version
ID:	21106   Click image for larger version
ID:	21107   Click image for larger version
ID:	21108   Click image for larger version
ID:	21109   Click image for larger version
