Hi All,
I was asked to scan an A8 3.0 TDI for a reasonabvly local enthusiast. Here is the resultant log. I have edited the owner details even though I have his permission to publish this. Any comments? Tuesday,23,October,2018,14:40:04:58733 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: 18.2.1.2 Data version: 20180518 DS287.1 www.Ross-Tech.com VIN: WAUZZZ4E46N0xxxxx License Plate: WV05xxx Mileage: 242610km-150750mi Repair Order: #01 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76 77 VIN: WAUZZZ4E46N013222 Mileage: 242610km-150750miles 00-Steering Angle Sensor -- Status: Sporadic communication error 1000 01-Engine -- Status: Malfunction 1010 02-Auto Trans -- Status: Malfunction 1010 03-ABS Brakes -- Status: Malfunction 1010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 1010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 1010 16-Steering wheel -- Status: Malfunction 1010 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 1010 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 1010 36-Seat Mem. Drvr -- Status: Malfunction 1010 37-Navigation -- Status: Malfunction 1010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 1010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 1010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C Component: 3.0L V6TDI G000AG 0030 Revision: --H01--- Serial number: AUX3Z0E9375520 Coding: 0011973 Shop #: WSC 02313 785 00200 VCID: 2959D191801C4F0C50-807C 8 Faults Found: 000260 - Mass Air Flow Sensor (G70) P0104 - 001 - Intermittent - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 212488 km Time Indication: 0 Date: 2018.02.22 Time: 00:03:26 Freeze Frame: RPM: 273 /min Torque: 234.0 Nm Speed: 0.0 km/h Duty Cycle: 80.9 % Voltage: 10.03 V Absolute Pres.: 999.6 mbar Mass Air / Rev.: 0.0 mg/str 000258 - Mass Air Flow Sensor (G70) P0102 - 001 - Signal too Low - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 212488 km Time Indication: 0 Date: 2018.02.22 Time: 00:03:29 Freeze Frame: RPM: 819 /min Torque: 210.6 Nm Speed: 0.0 km/h Duty Cycle: 80.9 % Voltage: 12.62 V Absolute Pres.: 1009.8 mbar Mass Air / Rev.: 487.6 mg/str 004195 - Fuel Pressure Regulation P1063 - 004 - Control Range Not Reached - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 212488 km Time Indication: 0 Date: 2018.02.23 Time: 00:05:20 Freeze Frame: RPM: 798 /min Torque: 230.1 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 13.91 V Pressure: 184.6 bar Duty Cycle: 51.3 % 005705 - Powertrain Data Bus P1649 - 001 - Missing Message from ABS Controller - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 5 Reset counter: 255 Mileage: 0 km Time Indication: 0 Date: 2018.03.26 Time: 00:00:00 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h (no units): 24.0 Voltage: 11.02 V (no units): 1.0 000568 - Manifold Pressure / Boost Sensor (G31) P0238 - 001 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 4.980 V Voltage: 10.49 V Absolute Pres.: 979.2 mbar Temperature: -90.0°C 000275 - Intake Air Temp. Sensor (G42) P0113 - 001 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 10.49 V Absolute Pres.: 1009.8 mbar Temperature: 108.0°C Temperature: 10.8°C 000566 - Manifold Pressure / Boost Sensor (G31) P0236 - 001 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 4.980 V Voltage: 5.70 V Absolute Pres.: 979.2 mbar Temperature: -90.0°C 001393 - Brake Switch (F) P0571 - 001 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 14:02:47 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 10.72 V (no units): 0.0 (no units): 0.0 Bin. Bits: 00000100 Readiness: 0 3 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4E0 910 156 F HW: 09L 927 156 Component: AG6 09L 3.0lTDI RdW 0090 Revision: --H01--- Serial number: 4002839 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B6C74-8070 8 Faults Found: 18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:49 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 4.0°C T.B. Angle: 0.0° 18271 - Powertrain Data Bus P1863 - 001 - Missing Message from Steering Angle Sensor - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:35 18290 - Powertrain Data Bus P1882 - 001 - Missing Message from Electric Parking Brake Controller - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:00 18289 - Powertrain Data Bus: Missing Message P1881 - 001 - Acceleration Request - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:00 18275 - Powertrain Data Bus P1867 - 001 - Missing Message from Steering Wheel (J527) - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:50 16944 - System Voltage P0560 - 000 - Malfunction - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 40 Mileage: 0 km Time Indication: 0 18288 - Powertrain Data Bus P1880 - 001 - Missing Message from Diagnostic Gateway - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:48 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 9 Reset counter: 40 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:13:04 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008357 Shop #: WSC 00001 000 00000 VCID: 224BC6BDFD2A9C5411-8076 2 Faults Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H07 0160 Revision: 01604707 Serial number: AUX3Z0E9375520 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFA455EBF606843F-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 7 Faults Found: 02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02241 - Engine Control Module; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:20 00192 - Rear Left Door Handle Touch Sensor (G417) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 76 Mileage: 0 km Time Indication: 0 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:56 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 12 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:06 00166 - Access/Start Authorization Switch (E415) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 14 Reset counter: 116 Mileage: 212304 km Time Indication: 0 Date: 2018.02.16 Time: 00:01:22 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670112 Shop #: WSC 00000 785 00200 VCID: 2345C3B9E230955C1A-8076 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 13:50:28 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 76 Mileage: 0 km Time Indication: 0 Date: 2005.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A Component: Interfacebox H43 2120 Revision: 00000000 Serial number: 300BJ057548940 Coding: 0000002 Shop #: WSC 00000 785 00200 VCID: 2E53228DB9F2283485-807A Subsystem 1 - Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 Subsystem 2 - Serial number: 318BP057515187 Subsystem 3 - Serial number: 7401.02.0500000000218B0158˙ Subsystem 4 - Serial number: 8B0158˙ 6 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:57 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:26:40 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:03 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:29 Freeze Frame: Bin. Bits: 01 02103 - Control Module 2 for Vehicle Electrical System (J520) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:57 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 3 Reset counter: 116 Time Indication: 15 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: User\4E0-910-043.lbl Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000062140 Coding: 1132625 Shop #: WSC 02311 785 00200 VCID: 1C37F845DF4EAAA4DB-8048 13 Faults Found: 00716 - Air recirculation Flap Positioning Motor (V113) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 209 Reset counter: 76 Mileage: 241771 km Time Indication: 0 Date: 2017.09.20 Time: 10:16:18 Freeze Frame: Voltage: 13.50 V Temperature: 21.0°C (no units): 192.0 (no units): 34.0 Temperature: 40.0°C 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 18 Mileage: 241771 km Time Indication: 0 Date: 2017.09.20 Time: 10:16:19 Freeze Frame: Temperature: 22.0°C 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 115 Mileage: 241775 km Time Indication: 0 Date: 2017.09.20 Time: 12:11:30 Freeze Frame: Voltage: 13.40 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 140 Reset counter: 102 Mileage: 241828 km Time Indication: 0 Date: 2017.09.21 Time: 09:34:28 Freeze Frame: Voltage: 13.70 V 00003 - Control Module 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242599 km Time Indication: 0 Date: 2017.10.20 Time: 20:45:31 Freeze Frame: Temperature: 20.0°C 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 12 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:10 Freeze Frame: Bin. Bits: 00011111 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:31 Freeze Frame: Bin. Bits: 00011000 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:41 Freeze Frame: Bin. Bits: 00011000 01853 - Heated Seat; Left Front (Z45) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Temperature: 25.0°C 01854 - Heated Seat; Front Right (Z46) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Temperature: 25.0°C 01855 - Temperature Sensor for Heated Seat; Left Front (G344) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Temperature: 25.0°C 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Voltage: 11.30 V 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No HW: 4E0 907 279 L Component: WWS NO RESPONSE Coding: 0123001 Shop #: WSC 02313 785 00200 VCID: 55A1AD61FCE43BEC24-8000 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 02313 2 Faults Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.28 Time: 23:20:37 00908 - Control Module for Wiper Motor 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 31 Reset counter: 76 Mileage: 242614 km Time Indication: 0 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 63C583B9A2B0D55C5A-8036 8 Faults Found: 01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145) 009 - Open or Short to Ground - Intermittent 00588 - Airbag Igniter; Driver Side (N95) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01587 - Igniter 2 for Airbag; Drivers Side (N250) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - Intermittent - MIL ON 00591 - Seat Belt Switch; Driver (E24) 010 - Open or Short to Plus - Intermittent 00592 - Seat Belt Switch; Passenger (E25) 010 - Open or Short to Plus - Intermittent 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 65C19DA1AC84AB6CB4-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 5 Faults Found: 01426 - Controls in Steering Wheel (E221) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 66 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:23:55 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 6 Fault Frequency: 23 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:08:15 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:53 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 10 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:27 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 F HW: 4E0 920 950 F Component: KOMBIINSTR. VDO H53 0200 Revision: D05 Serial number: AUDID3E1000779 Coding: 0000413 Shop #: WSC 00011 067 57207 VCID: 275DD7A99608797C46-8072 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 51 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:51 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:19 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0100 Revision: 0000000B Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3BFE5DD57AD494C9-804E 5 Faults Found: 01406 - No Flame 000 - - 02251 - Heater Unit Locked 000 - - 33477 - Terminal Status Unknown - 004 - - Intermittent 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent 02095 - Component Protection Active 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H10 0080 Revision: 10 Serial number: 19003052170092 Coding: FCFE7FDE2B3504 Shop #: WSC 02313 785 00200 VCID: 275DD7A99608797C46-8072 14 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 30 Reset counter: 116 Mileage: 241790 km Time Indication: 0 Date: 2017.09.20 Time: 12:41:33 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 5 Reset counter: 116 Mileage: 241847 km Time Indication: 0 Date: 2017.09.21 Time: 10:02:04 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:08:11 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:55 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 10 Reset counter: 116 Mileage: 0 km Time Indication: 0 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 10 Reset counter: 116 Mileage: 0 km Time Indication: 0 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 95 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:03 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBG8229001 Shop #: WSC 00000 000 00000 VCID: 1C37F845DF4EAAA4DB-8048 4 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:08 00474 - Control Module for Immobilizer 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 83 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:08:12 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:50 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 92 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:08:12 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H07 0160 Revision: 01604707 Serial number: AUX3Z0E9375520 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFA455EBF606843F-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 7 Faults Found: 02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02241 - Engine Control Module; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:20 00192 - Rear Left Door Handle Touch Sensor (G417) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 76 Mileage: 0 km Time Indication: 0 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:56 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 12 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:06 00166 - Access/Start Authorization Switch (E415) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 14 Reset counter: 116 Mileage: 212304 km Time Indication: 0 Date: 2018.02.16 Time: 00:01:22 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: User\4E0-910-158.lbl Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 015 0210 Revision: 00000017 Serial number: 00000000025011 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C989B1B8ACC74C48-8034 3 Faults Found: 01864 - Air Outlet Motor; Rear Right (V219) 003 - Mechanical Failure - Intermittent 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285FD4959B1676044F-807C 5 Faults Found: 01598 - Drive Battery Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 23 Reset counter: 116 Mileage: 0 km Time Indication: 0 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 116 Mileage: 0 km Time Indication: 0 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 4 Reset counter: 168 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:03 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 7 Reset counter: 168 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:39 01398 - Signal Conductor for Central Locking; Doors Open 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 168 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:35 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670122 Shop #: WSC 00000 785 00200 VCID: 2345C3B9E230955C1A-8076 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 3 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 13:50:28 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 76 Mileage: 0 km Time Indication: 0 Date: 2005.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C Component: MNS ECE H44 0850 Revision: 00000000 Serial number: 305BE057572015 Shop #: WSC 02313 785 00200 VCID: 3B751BD97A80CD9C32-806E 2 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 13:52:15 02445 - Disk Drive Initialization Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:36 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000426700008 Coding: 0036004 Shop #: WSC 02313 785 00200 VCID: 1D31F541C454A3AC2C-8048 2 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:00 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 3 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2004.03.25 Time: 00:02:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 204FCCB5F3268E4407-8074 4 Faults Found: 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 241952 km Time Indication: 0 Date: 2017.09.23 Time: 10:04:02 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 5 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:06 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:10 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040503010096 Coding: 0004857 Shop #: WSC 02313 785 00200 VCID: 275DD7A99608797C46-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 10 Faults Found: 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 186 Reset counter: 76 Mileage: 242226 km Time Indication: 0 Date: 2017.10.03 Time: 09:12:58 01503 - Bulb for 3rd Brake Light (M25) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 8 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:18 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 34 Reset counter: 116 Mileage: 0 km Time Indication: 0 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 187 Reset counter: 76 Time Indication: 1 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 8 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:34 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:35 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 12 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:05:52 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 15 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:04 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 80 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:06 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 K HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0440 Revision: PROD_01 Serial number: 00000000011655 Coding: 0000013 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B6C74-8070 3 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:50 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 5 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 13:49:46 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:32 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000056371 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E33F24DC952B8B435-804A 5 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 12 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:00 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 262140 km Time Indication: 0 Date: 2018.07.10 Time: 20:19:00 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 74 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 13:50:00 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 9 Reset counter: 116 Mileage: 0 km Time Indication: 0 Date: 2023.06.06 Time: 00:00:00 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 254 Reset counter: 76 Mileage: 242612 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 204FCCB5F3268E4407-8074 5 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2017.10.22 Time: 14:14:10 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 5 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2017.10.22 Time: 14:15:46 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000221 Shop #: WSC 00468 210 91510 VCID: 204FCCB5F3268E4407-8074 5 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Time Indication: 0 Freeze Frame: Voltage: 10.97 V Count: 247 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Time Indication: 0 Freeze Frame: Voltage: 8.80 V Count: 243 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Time Indication: 0 Freeze Frame: Voltage: 8.28 V Count: 41 02432 - Supply Voltage for Left Parking Brake Motor (V282) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11111100 Fault Priority: 1 Fault Frequency: 5 Reset counter: 76 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:34 Freeze Frame: Voltage: 12.01 V Count: 86 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 76 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:56 Freeze Frame: Voltage: 10.97 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 02311 785 00200 VCID: 62CB86BDBDAADC5451-8036 5 Faults Found: 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:26 00070 - Starting Battery Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 8 km Time Indication: 0 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:38 00255 - ABS Valves 015 - Cannot Be Tested at this Time - MIL ON Freeze Frame: Fault Status: 11101111 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:41 02233 - Left Headlight Power Output Stage (J667) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 76 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:03 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 L HW: 4E0 035 541 E Component: TUNER EU/US/RDW H42 0560 Revision: 00000000 Serial number: 396CV057505268 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2959D191801C4F0C50-807C 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 175 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:53 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 E HW: 4E0 919 146 C Component: TV analog TUNER H14 0270 Revision: 00000022 Serial number: 00000000003528 Coding: 0000003 Shop #: WSC 00000 785 00200 VCID: 2345C3B9E230955C1A-8076 2 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 5 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 13:53:06 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 3 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:19:04 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0510 Revision: 00000000 Serial number: 00000000006444 Shop #: WSC 00171 210 91005 VCID: 204FCCB5F3268E4407-8074 Subsystem 1 - Part No: 4E0 915 105 Component: von TU3 7023479471 Coding: 344530393135313035202054553337303233343739343731 Shop #: WSC 12345 123 45725 5 Faults Found: 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:38:06 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 01:31:31 02255 - Voltage Measuring Lead from Vbat 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 4 Fault Frequency: 10 Reset counter: 76 Time Indication: 0 Date: 2004.03.25 Time: 00:00:35 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:55 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:26 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 1E33F24DC952B8B435-804A 2 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 1E33F24DC952B8B435-804A 5 Faults Found: 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08720505401201 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 2149C9B1F82C874C08-8074 10 Faults Found: 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 32 Mileage: 241933 km Time Indication: 0 Date: 2017.09.22 Time: 15:42:43 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 20 Mileage: 241774 km Time Indication: 0 Date: 2017.09.20 Time: 10:26:31 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 29 Mileage: 241774 km Time Indication: 0 Date: 2017.09.20 Time: 10:26:31 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:02:20 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:05:48 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 18 Reset counter: 116 Mileage: 242614 km Time Indication: 0 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 116 Mileage: 0 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:00 01545 - Sensor for Parking Aid; Rear Left (G203) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 14 Reset counter: 76 Mileage: 241774 km Time Indication: 0 Date: 2017.09.20 Time: 10:26:30 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:28 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 F HW: 4E0 862 335 Component: Handyvorb2 H10 0580 Revision: 00000000 Serial number: 00000007541090 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B6C74-8070 2 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 41 Time Indication: 15 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 116 Time Indication: 15 End-------------------------(Elapsed Time: 03:43)--------------------------
