Go Back   A8 Parts Forum > A8 D4 > D4 - Fuel and Exhausts
D4 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again
Old 6th March 2025, 07:20 PM
Horrgakx Horrgakx is offline
Default Part for "Exhaust Pressure Control Valve 2"?
My VCDS reports: "1 Fault Found: 24749 - Exhaust Pressure Control Valve 2 - P04A2 00 [00100111] - Short to Plus"
Is this part the solenoid in the rear silencers?
A8L W12 (D4 2015)
Old 6th March 2025, 10:48 PM
Yes it is. With a 'short to plus', it may simply be a case of a loose connector, or with its location, possible water ingress or corrosion.
EDIT: Forgot to add. To test which is which, disconnect one of them, and run a scan, and you'll get a different error code. Once you've identified which is which, you can troubleshoot that one.
