hello everyone, guess what's leaking on my car again?
thats right, the rear output shaft seal - dripping onto the passenger side cat and giving off a nasty burning smell. i've had a look through the service history and it has already been replaced at least 3 times: 67k miles, 2006 86k miles, 2009 112k miles, 2013 each time, it has just had the seal replaced. as we all know by now, the original seal is not up to the job and audi modified the flange and seal. here is where my knowledge breaks down, and i am unsure of the exact parts needed to fit the new seal and flange? i'm currently installing ETKA to look up part numbers and try to figure it out myself. in the meantime, if anyone has done this and replaced with updated parts, the part numbers and exact parts required would be very helpful. additional reading: http://www.audipages.com/Tech_Articl...placement.html <- DIY to replace JUST the seal http://forums.quattroworld.com/a8/msgs/32544.phtml <- replacing with updated and modified flange, seal etc part numbers identified so far (according to the internet, not verified) 01V-409-809-A <- new flange/shaft (ZF part number 1058-336-122) 01V-409-524-B <- new cover with seal (ZF part number 1060-236-063) 01V-409-399-A <- just the new modified seal 018-409-399-B <- just the original flawed seal from my research, the modified seal will not fit correctly into the original cover *this post is incomplete but i am posting it because i need to reboot my pc now!
2001 S8 D2 ![]() Last edited by andycaca; 11th January 2015 at 01:44 PM. |
