2007 3.0tdi with std stereo (not bose or b&o). Just one speaker in each front door.
Since I got the car, there has been no sound from the drivers door. Changing the balance and fader across the ranges I can get sound from each extreme except the driver door. I removed the speaker and plugged it into the passenger door and it worked fine so I know it isn't the speaker itself. So I think the options are;- Wiring (nightmare to trace and check I assume) Amplifier (any tests I can do to check for output on that channel?) Or component protection (would it stop just one speaker?) Any suggestions or things I can test? Michael
2007 A8L 3.0TDi |
I don't know the answer but the silence sounds expensive
. Nite Blue 3.0L SE Quattro |
A thought (and probably bump to keep my thread alive!)
If you borrowed a vagcom would it tell me if there was component protection on the amplifier at least then I could take it in for a specific task and shop around. Michael
2007 A8L 3.0TDi |
Hi Michael,
Yes, VCDS would report the Amp in CP. I think it would also report if there is a short to ground or open circuit with the speakers. I guess you don't have VCDS, so as you have the door card off I would test the speaker wiring with a multi meter back to the plug at the amp. Wiring diagrams and pin outs can be found in the D3 tech dump, document 2-Current Flow, to assist you. Good luck ![]() http://forum.a8parts.co.uk/showthread.php?t=9347 Edit VCDS can also do a speaker test. It's worth borrowing if you can.
Matt 2004 A8 3.7q, 1998 A4 2.8q, 1994 Coupe 2.8q SORN, Last edited by mattylondon; 1st August 2016 at 08:30 AM. |
Thanks - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
Open the sound system module then Output Tests, this cycles a test tone to each speaker. Take a pair of ear defenders as it loud!
tried that - it IS LOUD - had to give up at first speaker as I thought you were joking about the defenders and I didn't have any! Julian
