Old 4th July 2019, 02:35 PM
hunker7 hunker7 is offline
Default Oil leak-sort of.
Hi guys, have a little problem where oil is getting pushed passed oil cap? Replaced oil cap, and found one of the breather pipes off, after sorting that it stopped for a while but now it's back again. Any ideas?
Old 4th July 2019, 03:14 PM
You have a breather problem somewhere and it's building too much pressure.
If you post more detail like what engine it is, MJ i'm sure will know the likely candidates to look for
Old 4th July 2019, 05:05 PM
Are there any valves? Checked pipes and can't see any cracks.
Engine is 2.8. I'm starting to feel bad now, I've asked MJ so many questions
Old 8th July 2019, 03:50 PM
Might be a broken or duff PCV Valve causing too much pressure - not too expensive for another one. . . .
Old 8th July 2019, 05:47 PM
Would you have a part number? Can't find it anywhere on parts catalog.
Old 8th July 2019, 06:24 PM
I've got a spare one kicking around somewhere, I'll see if there's a part number on it if I can find it.
Edit: 077 103 245 B Loads on eBay. Not sure of the condition of the diaphragm in mine though it works OK.
I think it's the same unit for loads of different VAG engines.
Old 22nd July 2019, 08:09 AM
Ooops, sorry I missed that.
Old 22nd July 2019, 09:46 AM
Two links you might want to check out. Neither relates directly to the 2.8 V6 in the Audi, but they are for a 2.8 V6 fitted in a Passat, so in theory, should be the same or very similar (but then we know that VAG never keep anything the same!). If nothing else, they will give you an idea of what you're looking for.
This first one is a diagnostic procedure for determining if you have a leak, and requires a pressure gauge and VCDS:
https://web.archive.org/web/20120412...leakhowto.html
The second one is a YouTube video showing replacement of the entire breather system:
https://www.youtube.com/watch?v=4_BVzgOb2rk
