Old 1st August 2024, 05:24 PM
Default My Weird Engine Squeak is Back
Before the annual meet in June I had noticed a repetitive squeak coming from the engine. Others noticed at the time as well. After getting back, I investigated the alternator as a possible source, and replaced it as the rear bearing on it was shot. At the time, my squeak disappeared, so assumed that was the culprit.
Well, it's back again. So I took off the timing belt covers to check everything out, and noticed two things. The first is that the timing belt was rubbing on the lower cover. The highlighted section of the photo shows where it has been worn down slightly.
The second is possibly more worrying. With the covers off, I was watching closely and listening for the squeak. There wasn't any squeak, but that may have been because the covers were removed or because the engine had warmed up. I'll start the car tomorrow with the covers off and see if the squeal is still there or not.
However, the visual check resulted in the following short video. As you'll see, the belt is moving in and out on that particular pulley, and also showing the same slight movement on all the pulleys. When I did the front end of the car last April (2023), all the components were replaced and every single nut and bolt was torqued to spec, and the squeak only appeared this year. For those parts of the belt I can reach, it all seems tight. Can't really check the pulleys as they're all under tension from the timing belt.
https://youtu.be/_XDH7pnG8tM
Old 1st August 2024, 08:38 PM
I had something similar on my old 2.8QS. Found it to be the bearing on the tensioner that was wearing and creating slight play. Didn't notice it until I released the tension on the belt.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 2nd August 2024, 08:37 AM
Saff Saff is offline
Hi Sean,
As Paul mentions and after watching your video something is either out of alignment or is allowing the belt to run a bit wonky. To ask the bloomin' obvious the belt, rollers and tensioner were all of the highest quality? Sorry to ask as I'm aware of your attention to detail. Obviously something is wonky and all I can think is that one of the components has failed. I wish you good luck.
2010 D4 SE Executive 4.2 TDI
Old 2nd August 2024, 09:34 AM
No need to apologise, but highest quality is something I literally can't afford. No idea which part was which brand, but the components were either INA, Meyle, Febi or ContiTech.
I had another look at it last night and was wondering how I could check the pulleys and tensioner without having to pull it all apart again. That's if I can even access them.
Would this possibly work? Turn the engine by hand to get it into the service position. Place the bar across the top and lock the crank. If I can get access to the tensioner, release the tension on it (I'm assuming it works the same as the one on the serpentine belt). I think the answer is no looking at the timing belt before it was tensioned, because it's only the tensioner that I could check. The pulley to the right of it and the water pump above still have tension on them.
Name:	IMG_20230204_102234_597 (Medium).jpg
Old 2nd August 2024, 03:39 PM
Your choice of parts seems to be excellent.
Wouldn't you need to time up the engine and lock the crank AND the cam pulleys before releasing any belt tension? Sorry again to state the bleedin' obvious.
Just thinking aloud, I'm sure the cam and crank sprockets would be true so any wobble would have to be in the renewable parts or perhaps even the belt itself?
Old 2nd August 2024, 06:20 PM
I'm sure that's what I suggested, or at least meant.
That's my thinking as well. One of those three in the middle, which whatever way you look at means the front end off and another strip down.
Never thought about the belt being a possible culprit, but either way, I'm hoping that when I can get around to it, the culprit is easy to spot.
Just what I need at this time of year when I'm just about to fork out another 41% extra for the car insurance!
EDIT: Question. Opinions on Gates and SKF as parts option.
Last edited by steamship; 2nd August 2024 at 07:03 PM. Reason: Question about Parts Manufacturers
Old 14th August 2024, 09:50 AM
And the result was what?
Almost certainly not relevant but the weird untraceable squeak from my engine bay turned out to be the alternator; identified and fixed by MJ.
Also, watching your video closely there's a lighter mark on the edge of the belt that comes round every second or so. That seems 100% synchronised with the lateral movement of the belt on the pulley.
So, my conclusion is that the belt isn't quite straight and that's causing the lateral movement. Manufacturing defect?
Old 15th August 2024, 11:09 AM
Almost certainly not relevant but the weird untraceable squeak from my engine bay turned out to be the alternator.
1. Totally forgot to update it. No squeak at all.
2. Having spoken with BrianB (donp38) at the annual meet, I checked and subsequently replaced the alternator as the rear bearing were shot. The squeak went away, so I assumed that was the cause at the time.
3. Never even noticed that. Went and checked and that is wear on the belt, either from rubbing on the bottom plastic cover or the side of the metal pulley.
4. Michaela mentioned that it could be the belt itself, but until I strip it down 'again', I won't know for sure.
Old 25th September 2024, 09:27 PM
donp38 donp38 is offline
Good result.
I am glad you caught it in time.
Best wishes
Old 27th September 2024, 11:36 AM
I sincerely hope so. I forgot to provide a further update, but dealing with family health issues recently, so the car isn't getting a look in.
I replaced the entire set, and checked every pulley and tensioner, new vs. old, as I was replacing them. Honestly couldn't see or feel any difference between them. Maybe Michaela was right all along, and it was the belt, as apart from a visual inspection, there wouldn't be anything else I could check on it.
