Old 5th July 2014, 10:36 PM
Default Can Replacement Speedo Have Mileage Changed
Noticed that daviesbike is having a spring clean and has a couple of A8 speedos, although I think they're for a D3. It got me thinking since my speedo is faulty. No comms between it and Sat Nav, fuel MPG shows as 200 and backlights temperamental. If I was to fit another speedo, is it possible to code in the mileage that's on my current one, or would I be stuck with whatever the replacement one came with?
Old 5th July 2014, 11:19 PM
Lee S Lee S is offline
Must be able to. I had my cluster changed by Audi under warranty due to a flickering back light and the new cluster had the same mileage on when I got it back. VCDS?
Lee
2017 Nissan Leaf Tekna
Old 5th July 2014, 11:41 PM
I think that Guys ones are for a D3 Sean looking at them. The D2 FL cluster if I remember is coded to the keys that you have immobiliser wise so if you do try and change it an Audi dealer with full VAS set up would need to sort that bit out to so that your keys talk to the immobiliser - not even sure it's possible but you'd need to ask Audi the question. IT may know this for certain and be along in a bit
Old 6th July 2014, 06:28 AM
Mileage officially can only be changed once on new cluster that has less than 100km on it. If you want it changed later you need to desolder EEPROM, read it in reader, modify data, write it back in the chip and solder it back. On some clusters it can be changed with aftermarket gear like VAGTacho or VAG Commander. If you are swapping clusters it's probably easier to swap eeprom chip from the old cluster into the new one.
Old 7th July 2014, 08:22 PM
Sounds like too much hassle, and don't want to go to the expense of a new cluster. Will just live with the issues. Thanks.
Old 7th July 2014, 08:43 PM
mannyo mannyo is offline
I looked into replacing the cluster on my old D2 as it had a problem with the mileage display, I also gave up due to the hassle factor and put up with the fault.
Manny
Past
Old 8th July 2014, 01:54 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Contact a good mobile immobilizer/key guy and they should be able to do it for you.
I know of two.
You supply the clocks and they can code the clock, car and keys.
You'll have the same keys and miles (unless you want to clock it but I don't recommend that) and away you go.
Let me know if you want their details.
[center]
06 3.0TDI Quattro:
Options:
Old 8th July 2014, 10:55 PM
Cheers Scott, but as Manny said, it's too much of a hassle as I can live with the faults. The only one I could find on eBay was £100, which I'd rather spend on something better for the car.
