Old 14th April 2015, 10:24 PM
centurion centurion is offline
Default boot opening - interior door switch
hi,
i have bit of an issue with a boot... first thing first it does not open up from the switch on driver's door [fuel flap option works fine though ]. I tried the fuse, looked at VCDS [no errors or issues flagged] and i'm sort of left in no man's land at the mo?! Any suggestions?
also worth mentioning [which is yet another annoying thing] is that as soon as you start the car you cannot open the boot!? Again i looked in VCDS for obvious errors and haven't found any so guess it is just the way it's coded. Which brings me to question #2 - can it be re-coded in VCDS to open up when doors are open and close when lock is ON/manually selected etc?
cheers
