Old 14th April 2015, 11:25 PM
If you do an auto scan then save the log at the end of the scan, you will then find that in your vcds folder in a folder named logs.
Copy all the text from the log and post it here.
As for you issues the behaviour is normal as far as i am aware because i have noticed it too on my car when taking stuff to the dump. if the engine is running you cant open the boot from outside which makes sense as you don't want some ned stealing your stuff.
If your button on the drivers door worked you can open the boot that way with the engine running.
