Old 16th November 2020, 02:07 PM
The_Laird The_Laird is online now
Default Bonnet struts
I think my bonnet struts have come to the end of their life as the bonnet often shuts itself when I leave it open.
Are there any recommended makes of replacement strut, or makes to avoid (Chinese ones will be avoided, of course!)?
Old 16th November 2020, 04:59 PM
The brand names I came across for original suppliers are Stabilus, Lesjofors (two dots above the first 'o'), Triscan, Quinton Hazell, Delphi and Febi Bilstein, and I've only heard of the last two.
Lots available on eBay from the likes of Meyle and Magneti Marelli as well as 'other' brands, but MJs opinion is probably the best.
Part number by the way is 4D0823359F.
UPDATE: Forgot to add the specs for them if looking at other manufacturers for them. Length - 530mm, Housing diameter - 18mm, Piston rod diameter - 8mm, Eject force - 245N, Stroke - 215mm
Old 16th November 2020, 05:05 PM
Thanks for the data, Sean. Very helpful.
Old 16th November 2020, 09:22 PM
Ronin Ronin is offline
I think phaeton chrome struts fit the A89 D2 just like the rear boot struts
Old 17th November 2020, 09:45 AM
johnny_quattro's Avatar
The original struts that failed to lift the bonnet on my car were made by a Belgian company called HINSCHA with the '4027CV 0245N' code printed on the side of the strut casing. I did a bit of searching around on 'tinterweb' and eventually plumped for a set of front struts called Nitro Lift for my car from SGS Engineering. Work really well, easy to fit. I think they're up north somewhere, Derby (I just checked). I've attached an image of the measurements in PNG format.
Last edited by johnny_quattro; 17th November 2020 at 09:58 AM. Reason: Added PNG image
Old 17th November 2020, 10:03 AM
Ha ha! Only a Londoner could call Derby “up north somewhere”
But thanks for the recommendation. I think my boot struts were from SGS, so I’ll check them out.
Old 17th November 2020, 08:43 PM
Ah, perhaps my soft spot for Derby didn't come through in my post. Got a childhood friend who lives in Mickleover, and a mate of mine used to work at RR before being made redundant. Top people 'up north' in my book, including SGS who kept me fully updated on my enquiry and subsequent order for the front struts. I'm going to blow your mind now by telling you that I made it all the way to Newcastle once to see a man about some wheels. Norretal makes a fine cup of tea
Old 18th November 2020, 06:22 PM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
+1 For SGS, use them all the time for struts in work
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 18th November 2020, 06:44 PM
I suspect the struts you get are a smidge bigger.
Old 18th November 2020, 07:19 PM
Contacted SGS as the bonnet struts aren’t listed on their web site
