Old 20th February 2021, 07:14 PM
S81 S81 is offline
Default Replacement water pump
I've removed the water pump( shaft driven) as I thought the block o ring was weeping engine oil slightly ,(only seen it when I took sump off )but when I got it removed i discovered its actually leaking from a weep hole in the bottom of the pump ,i'm assuming theres a seal inside the pump that's leaking ,does anyone know who made the pumps for Audi it's stamped what looks like UT austria ,i'm going to change pump rather than refurb it as it's fairly nasty job to remove and even nastier to refit and don't want to have to do it a 2 nd time if refurb wasn't successful
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 20th February 2021, 07:28 PM
S81 S81 is offline
I made a mess of attaching the pics on last post
ID:	25614   Click image for larger version
ID:	25615   Click image for larger version
ID:	25616   Click image for larger version
ID:	25617   Click image for larger version
Daily driver
Previously owned
Old 20th February 2021, 07:44 PM
Came across a GK and Vaico but the names don't mean anything to me (whether those are original manufacturers or after market), but the latest revision of the pump is 079121010D. Around £250 from the dealer.
Old 21st February 2021, 07:47 AM
S81 S81 is offline
Thanks Sean ,i want to fit an oem as it's in a difficult location ,i'll wait and see if anyone knows who made them for Audi and if not I'll get one form tps /dealers
Daily driver
Previously owned
Old 27th February 2021, 08:49 PM
S81 S81 is offline
New pump arrived and fitted, its a fairly unpleasant task as there's no room as usual( from dealer, couldn't find who makes them ,new pump has same stamp of ut as per the old one )
Daily driver
Previously owned
