Old 5th July 2021, 11:09 AM
rory_pamphilon's Avatar
rory_pamphilon rory_pamphilon is offline
Default Air suspension - Strange Issue
Hi,
Had an 07 3.0tdi Sport for 2 years now and suspension had been faultless so far. Yesterday however whilst driving around town the yellow & green lights came on so I pulled over and the rear had sunk right down but the front looked ok. Took it home, retried it later and all was fine, went to the take away and no issues.
Tried again the today and this time the front is right down and wont raise, the same yellow & green lights are on.
I'm not too clued up on this but that cant be a leak if the problem is alternating between front and back can it? sounds more like compressor. I dont have access to Vagcom unfortunately.
*Edit* ... just tried again at lunch there and the front still wont raise, same green and yellow dash lights. i can actually hear either the air compressor or an air leak in the front passenger side wing also.
Thanks
