Hi everyone, been searching but not found exactly what I need….
Got an issue with central locking on my pf 4.2qs, I can hear the pump trying to do its thing, but nothing opens. Not being helped just now either by what I’m assuming is a faulty boot latch which I’m about to try replacing (I’m no good with spanner’s etc, I just like driving stuff….) Just wondering where to start looking for what I’m hoping is a leak or popped off pipe or something….. |
I'm assuming that the majority of stuff on the PF/FL models are in the same places, so if you can get into the boot, the pump for the central locking is located in the left hand side of the boot, behind the lining. There should be two pipes coming out, and if I'm correct, one serves just the drivers door and the other the other doors and boot.
Could be a leak, but there are two circuits so at least something ought to work if one circuit has a leak. The pumps are known to wear out so it might be that it just isn't moving any air any more. I'm sure there is a repair kit for them.
The door that I try to unlock will unlock and the boot (when the latch works)
2021 Q7 4M, 3.0tfsi MHEV Black Edition 2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek 1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE ** 1990 2.3 20v 7a Coupe Quattro **SOLD** 1996 2.6 v6 cabriolet, Isis red metallic **SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb **DEAD ![]() Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold |
Ok so that says the pump is working (and will probably unlock the fuel door as well), but you have a leak in the door circuit. That could be as simple as one of the door locks (albeit not simple to find), or it could be a leak in the actual pipework.
I think the first thing to try is see if you can hear one of the doors hissing during lock/unlock. |
Thanks, that’ll be one for tomorrow, along with boot latch replacement and wing mirrors
Just a quick update, boot latch replaced - boot now locks but…….
As soon as I put key in ignition and turn to start car, the boot releases. I’ve learnt to live with it as doesn’t lift during driving, I then just have to (once cars stopped and key out) lift and close the boot lid which then latches and doesn’t try to open itself again. It then stays firmly locked shut until the keys again in ignition. This’ll be one to investigate further when I get back home probably after Christmas but if anyones got any suggestions as to wtf is causing it, thanks in advance! Wing mirrors were a ballache, thanks to mikkijayne for heads up on that lol. Managed to find one was just a cog needing replaced, now works perfect so didn’t need removing etc the other is still kaput Still need to have a proper listen at each door for hissing of cl but pumps still very active
That feels like it might be the switch in the B-pillar. I can't remember the logic for when it's active, but I'd start by unplugging that and see if it has any impact. If not, you may be looking at a new central locking module.
Somewhere else to have a listen is at the boot lock mechanism in the rear light cluster.
