Hi folks, after replacing the residual pressure valve on a front air strut I am unable to complete the adaptation.
In Adaptation mode - The front drops first then raises a bit but not excessively high. The rear drops to very low then the fault comes up and I get the error message on VCDS. I am getting the error code - 01400. Upper limit Exceeded. What does this mean exactly? I tried basic settings and are able to pressure the front and rear struts, pressure dumping and pressurising front and rear working perfectly. So it’s not the valve block (plus I replaced this with OEM grade 2 years ago). So my question is there any way to get past the 01400 fault which appears to be stopping the adaptation process. I did recently replace all the level sensors recently - could it be that? Any comments or suggestions appreciated, Thanks 👍
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. ![]() |
**UPDATE**
Using VCDS looking at Measuring Blocks I found that when using Basic Settings to force the suspension to lower and lift - the front suspension would display the lifted height increased however, the rear suspension displayed the opposite! This suggested the rear level sensors linkages were being activated incorrectly. as it turns out that once I disconnected the lower linkage to the swing arm and flipped around the linkage - the sensors now read correctly when using basic settings to force lifting, and dropping. With the wheels back on I again tried Adaptation which worked perfectly!👍 all in all a positive result, so human error on the level sensors replacement… now the car sits correctly and will purchase a couple OEM grade minimum pressure valves for the struts as these can fail even after two years new. I purchase these from Miessler Automotive Parts - Germany. hoping that my experience can help others
Never had issues with them, but have read/seen numerous times where owners had problems with suspension height, with some being extremely high (for a D3), and all were caused by the linkage being the wrong way round, so something people are prone to doing. Glad you got it sorted.
