D4 - Everything Else Holding forum for all D4 banter until membership grows and we'll expand out |
Well, it's that time of year, and you expect the heater to work?
Nope, took a ride today, and the only heat was off the heated seats. Took a scan, and found: Address 08: Auto HVAC Labels: 4H0-820-043.clb Control Module Part Number: 4H0 820 043 D HW: 4H0 820 043 D Component and/or Version: Klima 3 Zonen H14 0061 Software Coding: 3621002800 Work Shop Code: WSC 02313 785 00200 ASAM Dataset: EV_AirCondiFront 001050 (AU64) ROD: EV_AirCondiFront_AU64.rod VCID: 21503B5361C9138A302EBB9-8075 1 Fault Found: 0378 - Coolant Circulation Pump B10D0 04 [009] - Internal System Fault Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 217 Mileage: 175128 km Date: 2016.11.11 Time: 21:03:57 Has anyone seen this before? is there a circulation pump just for the blowers? Where is it? Are they easy to change? Cheers
2011 A8 Executive 3.0 TDI Quattro |
