Hi all, I've got so far with parts, I've already changed the oil & filter but I need confirmation with the following if anyone can help please?
Thanks in advance.
A8L W12 (D4 2015) Last edited by Horrgakx; 24th May 2025 at 05:19 PM. |
All the part numbers you've listed are suitable for your W12.
As for the spark plugs, I can't find any information on the differences between the two, other than what it states on the page you linked to, and that is one has a solid SAE connector at the top, and the other has a crimped connector, and that single difference accounts for a weight difference of 9g.
Thanks very much!
Is a solid or crimped core preferred?
A8L W12 (D4 2015) |
The biggest difference is that VXUH22I uses more traditional design with narrow Iridium centre electrode and flat shaped Platinium disc on ground electrode, on IXUH22FTT ground electrode has thin Platinium tip, look at the pictures, you will see the difference. In theory thin tip may have better exposure and ignite mixture faster and more efficiently resulting in better efficiency reducing fuel consumption and increasing power but may wear out sooner and have shorter life. In real life for stock engine there is probably no noticeable difference.
For the connector, again there is probably no measurable difference in real life, crimped may have slightly higher resistance but considering that it's thousands of volts and very little Amps, I don't think it matters. It would matter if it was other way round with little voltage and lot of Amps. In theory also if not crimped properly it could work loose and separate. So in theory solid is better but in real life no difference unless there is manufacturing defect and not crimped on properly.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 25th May 2025 at 02:02 PM. |
