Old 2nd June 2025, 11:34 AM
Default Screen wash bottle replacement
Its all happening just before the meet! Screen wash bottle has sprung a leak.
Does it come out from the top or from behind the wheel arch liner?
Old 2nd June 2025, 12:31 PM
I should know this as I removed mine to give it a good internal clean two years ago when the front of the car was off. Looking at it as it is now, I reckon you can remove the airbox and headlight, and then take it out up the way.
You might be able to get it out through the wheel arch, but as you can see from the attached photo, you have to lift the reservoir almost two inches to clear the metal work it's bolted to, before pulling it back and down. Chances are you'll still have to remove the headlight and airbox.
Name:	IMG_20250602_132730_136 (Medium).jpg
Old 2nd June 2025, 04:29 PM
It happened to mine. Just decided to do it. They dont stay fixed too long.
Paul
Gosport UK
________________________
Polestar 2 Long Range
Audi S8 2002 FE Avus Silver / Extended Red Leather. https://forum.a8parts.co.uk//showthread.php?t=16187
Honda Jazz
Old 2nd June 2025, 05:37 PM
It comes out down through the wheel arch.
Bumper off.
Airbox out.
Headlight out.
Wheel arch liner out.
Old 3rd June 2025, 06:21 AM
Who designs this stuff? What a job just to replace a wash bottle.
Old 3rd June 2025, 04:22 PM
Someone who also sets the length of the warranty!
Old 3rd June 2025, 05:19 PM
It's unlikely to be the bottle itself unless it's broken by water turning to ice and expanding in severe winter.
On my old A6 the grommet between pump and bottle started leaking, was not easy to access but managed to change it from under wheel arch without removing bottle. Did not have any issues on D2 so don't know about D2 but it may be an option.
Old 3rd June 2025, 05:32 PM
It's unlikely to be the bottle itself...
Just in case it's one of the grommets, here's the part numbers for them, from the attached image:
#5 - 443955465
#6 - 431955465A
Name:	Screenshot 2025-06-03 182836.png
