Just noticed this starting today, the alarm goes off for a short time, maybe 30 seconds then stops. A bit later it goes off again!
A VCDS scan doesn't show much exciting EXCEPT low internal voltage (dying battery inside as ever) and (probably more relevant) 49-10 No Communications - Intermittent Any thoughts on what might be causing it and is there a quick way of silencing it, short of dismantling the boot liner and pulling its connector off! It's a bit of a pig to get to so I'd rather avoid that for now if possible. It's not the original bulky square alarm module, it's the slightly later but compatible rectangular version that might even have been from another Audi model.
Gave up in the end, took the dam thing out, all done in under half an hour.
Most difficult step was actually taking the connector off, it's not at all obvious how and the lead is extremely short. Prodding with a small flat screwdriver released the catch in the end. It's an 8L0 951 605A made by Bosch in Australia of all places! Might take it apart and see if there's any corrosion inside from failing batteries, if not I'll try to replace them.
Opened it up, batteries not good but PCB looks like it's probably OK.
Batteries are of a geometry that's NLA, though you could probably bodge a pair of 3-cell Varta ones to fit by making your own tabs. The battery is a 2*3.6v 140mAh Ni-Mh unit with 8 (yes eight!) soldered mounting pins, a bit weird! ![]() It's not obvious if the batteries supply just a 7.2v feed or if an intermediate 3.6v is also used. If I do try to repair it I'll take a 3-core lead (0, 3.6v, 7.2v) through the casing and fix suitable battery packs externally. 3.6v Ni-Mh are readily available.
That's pretty quick. Crazy price for new ones, which is why I never bothered replacing mine after the second one.
Been in there a few times so I know what I can get away with.
![]() Remove top trim strip around boot lid ( 2 clips with central plugs). Remove side panel cover over non-existent TV and CD (that's under the floor now). Remove net loop and next inboard clip on sill cover enough to free boot side panel. Wiggle side panel out at rear and push it away to get at the alarm siren fixings. The fact that I have nothing behind the boot side panel now really helps a lot - no big metal brackets and electronics boxes and cables to remove.
I took mine out years ago after a couple of attempts at fixing/replacing it. No-one pays any attention to a car alarm anyway!
Except insurance companies!
![]() I've taken the old batteries out by gently prising the mounting pins away from their faces, so I still have the pins soldered in place to help fixing replacements which are on order. Cleaned up the circuit board too - note to others - DON'T use isopropyl alcohol, it dissolves the green lacquer on the PCB! ![]() ![]()
