My front undertray, the big flat panel that goes rearwards from under the front bumper, is coming adrift. Not sure if that's what it's called though.
I think it's been missing a few retaining clips for a while and catching it over a kerb hasn't helped either. ![]() I can see that some clips are loose or missing from underneath and also where it joins the front lower edge of the wheel arch liners. There also seems to be a couple of the (same/similar?) clips missing from the wheel arch liners. I presume these are mushroom-shaped retainers with some sort of central peg that is pushed in after fixing to make it secure. Does anyone know the Audi or VAG part number, or whether generic trim clips can be used, if so what type and size?
It shows two pins are used. Not sure if it's both or one type depending on year?
8D0805121 (6X18MM silver) & 4A0805121A
Thanks for that, those are the push and turn to lock type which I didn't realise.
One of those is metal to use with speednuts, the other plastic for a different type of clip. Guess I need to go and look closely.
Etka calls it 'sound deadening', but everyone else uses undertray
![]() The steel 1/4 turns are 8D0 805 121 'Grip pin' They are held to the tray by 4A0 805 137 'Rubber washer' The clips they go in to are 8D0 805 960 'snap nut' I think there are six these in total, but mine is in bits still so not 100% on that. I know there are two on the little brackets which hang off the front panel, and two at the back of the tray. Most other models also have some at the edges of the front panel but Etka isn't clear on that. The plastic ones are 4A0 805 121A 'grip pin' Held in place by 4A0 805 137A 'lock washer' Clip in to 4A0 805 163 'clip' Four sets of these, two in each wheel arch. ![]() |
![]() There's also a fixing missing on the arch liner itself a few inches above that, any idea what that is?
Here are the eBay numbers for the ones I bought.
Plastic ones - 171655323682 - £2.99 for 10 pairs Metal ones - 221683540588 - £5.19 for 5 pairs
Cheers Sean, just the ticket.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 5th May 2016 at 04:37 PM. |
Good prices on those ebay listings - the plastic ones are £2 odd for each piece. Oh, and I just checked - there are only four of the metal ones. Two at the front, two at the back, and then two of each plastic one at each side. The one instance I've found so far of a D2 being simpler than B5 or C5 ![]() Last edited by MikkiJayne; 6th May 2016 at 01:55 PM. Reason: Corrected the part number |
Cheers, I've got a selection of similar trim fixings so one of those will probably fit, if not I'll get some from the local VAG dealer parts department next time I pass.
![]() It's like a mix of #40 and#63 so either would probably work. #33 seems too long. It worked fine for the wheel arch liner. ![]()
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 6th May 2016 at 12:53 PM. |
