Old 30th July 2016, 01:15 PM
mmarksx19 mmarksx19 is offline
Default No sound from drivers door speaker
2007 3.0tdi with std stereo (not bose or b&o). Just one speaker in each front door.
Since I got the car, there has been no sound from the drivers door. Changing the balance and fader across the ranges I can get sound from each extreme except the driver door.
I removed the speaker and plugged it into the passenger door and it worked fine so I know it isn't the speaker itself.
So I think the options are;-
Wiring (nightmare to trace and check I assume)
Amplifier (any tests I can do to check for output on that channel?)
Or component protection (would it stop just one speaker?)
Any suggestions or things I can test?
Michael
2007 A8L 3.0TDi
Old 30th July 2016, 07:20 PM
47p2's Avatar
47p2 47p2 is offline
I don't know the answer but the silence sounds expensive
Nite Blue 3.0L SE Quattro
Old 31st July 2016, 10:13 PM
A thought (and probably bump to keep my thread alive!)
If you borrowed a vagcom would it tell me if there was component protection on the amplifier at least then I could take it in for a specific task and shop around.
Michael
2007 A8L 3.0TDi
Old 1st August 2016, 08:09 AM
Hi Michael,
Yes, VCDS would report the Amp in CP. I think it would also report if there is a short to ground or open circuit with the speakers.
I guess you don't have VCDS, so as you have the door card off I would test the speaker wiring with a multi meter back to the plug at the amp. Wiring diagrams and pin outs can be found in the D3 tech dump, document 2-Current Flow, to assist you. Good luck
http://forum.a8parts.co.uk/showthread.php?t=9347
Edit
VCDS can also do a speaker test. It's worth borrowing if you can.
Matt
Old 10th August 2016, 09:00 PM
Edit
Hi Matty; I have VCDS but didn't realise I can do a Bose speaker test. Can you please explain briefly how you runi it?
Thanks - Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver.
Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years!
Old 12th August 2016, 09:18 AM
Thanks - Julian
Hi Julian,
Open the sound system module then Output Tests, this cycles a test tone to each speaker. Take a pair of ear defenders as it loud!
Matt
